jibbyman Posted March 10, 2014 Share Posted March 10, 2014 Hi to all , I have a 2001 td5 with 86000 on the clock -auto . When I run my climate control on full power hot or cold the car goes into limp home mode .The coolent pipes are not above xyz plug , a new battery fitted and putting out 13.6 v under load .I would change the xyz switch but as it only does it using the heater or air con on full power I have my doubts .Cheers Steve Quote Link to comment Share on other sites More sharing options...
elbekko Posted March 10, 2014 Share Posted March 10, 2014 Check the auto box ECU's ground. Quote Link to comment Share on other sites More sharing options...
jibbyman Posted March 10, 2014 Author Share Posted March 10, 2014 Thanks for the quick reply captain do you know the location of the gearbox ecu .cheers Steve Quote Link to comment Share on other sites More sharing options...
discokev Posted March 10, 2014 Share Posted March 10, 2014 Look at heater box condensation vent it leaks onto xyz switch I had to divert mine. Quote Link to comment Share on other sites More sharing options...
jibbyman Posted March 10, 2014 Author Share Posted March 10, 2014 Hi kev moved when I first had car .cheers Steve Quote Link to comment Share on other sites More sharing options...
