RMEHUNTER Posted March 19, 2014 Share Posted March 19, 2014 There is a pipe coming off the bottom of my TD5 turbo that came loose a couple weeks ago and sprayed oil on the exhaust (the connection to the block). I was able to clean it up and tighten it. 2 weeks later it came loose again. Should I try some sort of thread sealant or is this a sign of another larger issue? Thank you in advance for the help. Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted March 19, 2014 Share Posted March 19, 2014 Hi, I believe it's the turbo oil drain pipe you are referring too. If you say you've already tightened it up and its come loose again. i would remove the pipe fully, clean and inspect it. The thread on the pipe or block may have be damaged or the pipe itself may have degraded. When refitting it I guess a drop of thread sealant would hurt. Steve Quote Link to comment Share on other sites More sharing options...
RMEHUNTER Posted March 19, 2014 Author Share Posted March 19, 2014 I will order a new pipe. While waiting on the new one I backed the nut out and put a little sealant on it. I had to make a "custom" wrench as my hands are a little big for that spot. Quote Link to comment Share on other sites More sharing options...
jbs Posted March 20, 2014 Share Posted March 20, 2014 I made something similar for the stop solenoid on my 200 tdi's FIP-out of a 24mm open ended spanner John Quote Link to comment Share on other sites More sharing options...
