broken90 Posted April 7, 2014 Share Posted April 7, 2014 I'm not particularly clued up with electrics so excuse the novice question! My nearside front indicator has stopped working, the bulb was ok so as I has a spare complete indicator unit I swapped that and it still didnt work! The side repeater is working so I thought I'd link the live with that to get it working.... still not working! What am i doing wrong?! Surely as the rear and side repeater are working then its all correct from indicator stalk to the wing? Ive checked earths where possible, they seem ok. Many thanks Quote Link to comment Share on other sites More sharing options...
Mongrel Posted April 7, 2014 Share Posted April 7, 2014 Possibly run a continuity check across the bulb and holder, but, if the bulb's good, the earth's good and you apply power to the other wire then it has to light.....in theory. Quote Link to comment Share on other sites More sharing options...
western Posted April 7, 2014 Share Posted April 7, 2014 clean the bullet connections on the ends of the wires too. if your vehicle is pre 300tdi Quote Link to comment Share on other sites More sharing options...
broken90 Posted April 7, 2014 Author Share Posted April 7, 2014 Yes its a 200tdi. I'll give it a try in the morning. Its a struggle to see and get my hands in there, I have already cut some of the bukket connectors out as they were pretty crusty looking, maybe I'll have to do the whole lot Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 8, 2014 Share Posted April 8, 2014 Check that the wires are not caught between the outer and inner wing. Quote Link to comment Share on other sites More sharing options...
