Wrong UJ L90-84
CARP!
Ordered 4 new Uj for my propshafts. I order the RTC3346,'
Just removed one of the shafts and took out one of the UJ. Put in the new and........DOES NOT FIT!
The old (and new) does not have the RTC number on the UJ.
on the old I have the following information:
C5_28
33
626KN
Can some one tell me which UJ does is?
Thanks
they won't be marked with the LR part number.
measure the diameter of the bearing cap, there are 2 sizes, you probably need the other one,
is your new one to small or to big to fit the prop yoke ?
Sorry. Shouold have supplied some more information.
The caps are the same size, but the length is to short!
Thanks. Not sure how much that helps!?
The old one HAVE grease nipple. Should this mean that its the TVC100010?
Any one who can measure one for me?
Length Cap to Cap.
RTC3346 is about 82mm
My old is 93mm
Cross THICKNESS is 27mm.
Could be that this is the heavy duty UJ????
EDIT: Seems its only the front prop which has these UJ. Rear had the "normal" ones.
If I dont get an answer here today I will drive to Land rover tomorrow and see if they have one which we can compare.
found this http://www.southwalesprops.co.uk/propshaft/vehicles/landrover/landrover_defender.htm
scroll down to the 11th item first of 3 UJ info blocks. they don't give LR part numbers though, but it might help you sort what UJ you have/need
this page might help as well http://www.landroverexpedition.com/articles/universal-joint-differences/
Thanks but my old UJ is not listed there. I will continue searching.
The old is 27mm cap diam. and 93mm span cap to cap. The last in the list is 93mm span but its 30mm cap size.
this one, http://www.lrseries.com/shop/product/listing/12303/STC4807-PROPSHAFT-UNIVERSAL-JOINT.html?search=STC4807&page=1
http://www.island-4x4.co.uk/propshaft-95mm-suit-tvb100610-britpart-stc4807-p-3334.html has the info below on the page
New propshaft UJ to fit TVB100610
These are the larger 95mm UJ joints to fit the wide angle propshaft TVB100610
Yes, thanks. seems like that. Dont like that they state 95mm. Dont think the springclip would fit if 95. But my problem now is delivery time.
Need to visit Land rover tomorrow anyway to get my "death clip" for the clutch fork. Will check what they want. Looking at UK price Original is about 65 pounds. Means they will probably charge me 80-90 pounds here in sweden. Lets see.
Just seems odd that they have fitted a so much newer prop shaft to my 84 model.....Lets see. I will let you know tomorrow!
Thanks and sorry for all the questions marks....
/ Martin
:D Land Rover in Sweden had never sold a STC4807. They could get one for me. £100 !!!!!!
No thanks.
But I managed to find another supplier in Sweden. They just wanted £25 so I have ordered one.
I got my "death clip" from Land rover so hopefully I will update my clutch post later today!
Thanks everyone for now!
/Martin
