bernie Posted May 16, 2014 Share Posted May 16, 2014 I've just fitted a set of mobile storage systems internal window guards to my 1994 CSW defender. Did anyone else have trouble fitting them as I have had to cut the facia paneling which goes around the window, I had to cut the paneling where the window guards are bolted to allow paneling to get flush with body work. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted May 17, 2014 Share Posted May 17, 2014 Which guards, the side window or the rear windows ? Unless the side guards have been changed, or the trim changed they should fit. My Defender was used for the prototype of the side guards. I spent time making sure that once the guards were fitted, the trim fitted easily over the guards. My comment at the time to Nigel was " They have to fit perfect around the trim as some people will only want them for show " The trim panels are now off to give me more stacking room in the rear, If I remember I'll dig one out and see what's what. Quote Link to comment Share on other sites More sharing options...
bernie Posted May 17, 2014 Author Share Posted May 17, 2014 It was the side windows, I might have put brackets on wrong way round, as I found that the easiest way of fitting brackets as they wouldn't fit the way round that they were meant to go, for whatever reason. The vehicle is a factory fitted station wagon, so is not a case that it's been modified with wrong parts. I did find that I had to drill new holes for mounts at bottom as there was only one excisting place to bolt the bracket and that didn't line up either. I still have to do the right hand window yet so maybe that will work out better, Quote Link to comment Share on other sites More sharing options...
mmgemini Posted May 18, 2014 Share Posted May 18, 2014 Yes you will have to drill a couple of holes. IIRC the brackets are easily re-shaped to allow a good fit. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted May 18, 2014 Share Posted May 18, 2014 Any help ? Yes I did have to drill for the bottom brackets. I used body self tappers. Quote Link to comment Share on other sites More sharing options...
bernie Posted May 18, 2014 Author Share Posted May 18, 2014 Thanks for that, very usefull Quote Link to comment Share on other sites More sharing options...
