Sheffield Posted May 22, 2014 Share Posted May 22, 2014 Can I use an alternator from a V8 on a 300TDI if I change the pulley and rotate the front plate to suit the different mountings? Or will I get problems with the rev counter not reading correctly? I am not sure if the rev counter signal from the alternator is different, or if it is the same and just interpreted diiferently at the rev counter. Many thanks Quote Link to comment Share on other sites More sharing options...
discomikey Posted May 22, 2014 Share Posted May 22, 2014 why should it read any different? if the pulleys are the same ratio, the alternator will spin at the same relative speed per engine RPM but, of course i could be completely wrong Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted May 22, 2014 Share Posted May 22, 2014 Depends on the number of poles in the alt as well. Quote Link to comment Share on other sites More sharing options...
