geoffbeaumont Posted October 26, 2006 Share Posted October 26, 2006 Can anyone tell me the part number (or even better, spec) of the lower bolt that secures the upper tailgate latch on a Range Rover Classic? It's the longer one, that also holds the corner of the frame together. Also the ones that hold the upper tailgate handle on. Quote Link to comment Share on other sites More sharing options...
Orange Posted October 27, 2006 Share Posted October 27, 2006 Can anyone tell me the part number (or even better, spec) of the lower bolt that secures the upper tailgate latch on a Range Rover Classic? It's the longer one, that also holds the corner of the frame together. Also the ones that hold the upper tailgate handle on. My parts book is for 1986-1991 MY vehicles, but I expect it's a fairly standard set of bolts, so here goes: Lower latch bolt (same as the top ones) : 78591 (described as a SCREW) Upper tailgate handle bolts (again, described as a SCREW) : SE910481 (outer) and SE910441 (inner) - 2 of each apparently, but I have never taken one apart, so can't confirm that!! Hope that helps a little! Adrian Quote Link to comment Share on other sites More sharing options...
