MikeD Posted September 4, 2014 Share Posted September 4, 2014 Hi discovery people I am trying to re-use a discovery one fuse panel in a series and would appreciate a picture or list of what the original fuse ratings and uses were. The box I am after is the 27 way fusebox fitted to Discovery 1 up to around 1994 and the fuses are in three rows A1-9, B1-9 and C1-9 a picture of the handbook page listing the fuses showing their default values and purposes would be absolutely great I have searched online and can find the manuals/handbooks for the later Discovery 1 fuse panel but not the one I have which is 200tdi/3.5 v8/early 3.9v8 generation thanks in advance Mike Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted September 4, 2014 Share Posted September 4, 2014 It is something like this... I used a 200 tdi one on my early 110 to replace the glass fuses. I tried to more or less keep the fuses the same as on the disco and this was the print out I made to stick on the fusebox cover. It may vary slightly from the original, but not for the majority of stuff.. C1 Heated rear screen B1 Clock / Interior Lamps 10 amp A1 LH Headlamp - dipped beam 10 amp C2 Heated front screen B2 Rear Fog Lamp 10 amp A2 RH Headlamp - dipped beam 10 amp C3 B3 Stop lamps/gauges/indicators 15 amp A3 RH Headlamp - main beam 10 amp C4 B4 A4 LH Headlamp - main beam 10 amp C5 B5 Horn 10 amp A5 RH Side and Tail Lamps 5 amp C6 B6 Rear Wash & wipe 15 amp A6 LH Side and Tail Lamps 5 amp C7 B7 Aux Power Points 20 amp A7 Wipers and Reverse Lamps 15 amp C8 Hazard Lights 10 amp B8 A8 Heater Fan 10 amp C9 B9 Radio 5 amp A9 30 amp Quote Link to comment Share on other sites More sharing options...
MikeD Posted September 15, 2014 Author Share Posted September 15, 2014 Thank you, that is really helpful Quote Link to comment Share on other sites More sharing options...
