ajh Posted October 29, 2014 Share Posted October 29, 2014 I think the baffles in my aftermarket tank are intefering with the fuel sender float being able to get a full range of motion... I have a programable gauge and I would expect it to read full until the aux (flow through) tank drains a fair bit... but in reality what happens it is reads full for the first 800km, then rapidly within 200km reads empty until it runs dry. I think they probably intended a top-port sender to be fitted and my 110 (200TDI) has a side-port sender fitted. My question is; does anyone know of a non-swing sender that can be fitted from the side? I prefer to have things as accessible as possible for replacement. Fitting one from the top is an option but because of how things are secured it will involve cutting the floor and adding an access plate which I'd like to avoid doing if possible; and when I do it will likely be to fit a heated fuel pick-up which wouldn't work as a side pick-up and doesn't have a sender fitted (like the Hot-Stick). Any other ideas spring to mind? Thanks. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted October 29, 2014 Share Posted October 29, 2014 Wema do marine senders they do set lengths and made to measure generaly there top mount though. Mike Quote Link to comment Share on other sites More sharing options...
robertspark Posted October 29, 2014 Share Posted October 29, 2014 Etb instruments . Com Under analogue instruments then accessories at the bottom of the page is listed vdo dip tube fuel senders no cost but avail in various lengths Sorry can't seem to paste links on an iphone Hope it helps Quote Link to comment Share on other sites More sharing options...
