EEZIRYDER Posted November 17, 2014 Share Posted November 17, 2014 I'm scratching my head over a problem with my fuel solenoid. A couple of weeks ago my car died(fuel starvation) I rang the AA and as Sod's law dictates it started and run perfectly when he arrived. We faffed about a bit to try and recreate the fault but couldn't. I think it may be mud or water in a relay because it has done some serious off-roading previously but I'm not sure where the relay is. The Haynes manual says its a white wire that goes back to the engine control module. Mines a black wire and where is the engine control module? 95 disco 1 300tdi would love some advice Quote Link to comment Share on other sites More sharing options...
lyron Posted November 18, 2014 Share Posted November 18, 2014 at the rear of the injection pump you will find the selonoid. / fuel shut off. check that is operating correctly. we had a similar problem and ended up just swapping thje shut off. worth a try. ron. Quote Link to comment Share on other sites More sharing options...
EEZIRYDER Posted November 18, 2014 Author Share Posted November 18, 2014 Thanks for the reply Ron. I wired the solenoid direct to battery and it works perfectly, convinced it's a relay or the engine control module Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 18, 2014 Share Posted November 18, 2014 Does the car have a one button alarm or two button alarm? If it is a two button (= 1996MY) check out The Definitive Alarm Spider post in the tech archive on here http://forums.lr4x4.com/index.php?showtopic=86 Quote Link to comment Share on other sites More sharing options...
EEZIRYDER Posted November 19, 2014 Author Share Posted November 19, 2014 It's a 2 button alarm and this certainly sounds like the offender! Absolute gold dust that post. Thank you 1 Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 19, 2014 Share Posted November 19, 2014 That's what this forum is all about Quote Link to comment Share on other sites More sharing options...
