Springs Posted November 20, 2014 Share Posted November 20, 2014 Hi guys, the fuel gauge on my series 3 doesn't seem to work correctly. When full it seems to show correctly but other than that it never shows anything. any ideas / common issues? Quote Link to comment Share on other sites More sharing options...
Josh NZ Posted November 20, 2014 Share Posted November 20, 2014 Check the earth connections in the circuit, and then pull the sender out of the tank if possible and have a look at the float arm, it may be damaged or broken. The aftermarket senders are reasonably priced so replacement isnt a bad path to take. I had a britpart one once.. It was actually ok! Quote Link to comment Share on other sites More sharing options...
Springs Posted November 26, 2014 Author Share Posted November 26, 2014 is the tank accessible from under the drivers seat or do i have to start taking the tank apart from underneath? Quote Link to comment Share on other sites More sharing options...
dave88sw Posted November 26, 2014 Share Posted November 26, 2014 Lift out the drivers seat base and underneath is a plate held in with 6 screws, if you remove that, you can see the whole top of the fuel tank. From what you say, it sounds like the track on the sender is worn out and is only making contact when the float is at the top. Quote Link to comment Share on other sites More sharing options...
Springs Posted December 2, 2014 Author Share Posted December 2, 2014 just to update, it was a nice and easy fix. Removed the plate that was under the seat and was presented by the wire that was just touching the connector. Looked a bit worn so i crimped on a new connector, plugged it in and turned on the battery and result. The fuel gauge started to rise Quote Link to comment Share on other sites More sharing options...
Springs Posted December 10, 2014 Author Share Posted December 10, 2014 well it turns out that the sensor is still duff.. driving it around the gauge shows full for some time and then suddenly goes right down so i'm going to swap it out with a new one. also i noticed on the top of the sender that there are 3 take offs. one was for the gauge but any ideas what the other 2 do? Quote Link to comment Share on other sites More sharing options...
Josh NZ Posted December 10, 2014 Share Posted December 10, 2014 One is for a low fuel light, which would mean its a diesel type sender. Can't remember off the top of my head what the other one is.. I think they all go to the gauge! Quote Link to comment Share on other sites More sharing options...
Serious Series Posted December 11, 2014 Share Posted December 11, 2014 Is the sender a white plastic item if so one is not used others earth and gauge. Quote Link to comment Share on other sites More sharing options...
