Tanuki Posted November 30, 2014 Share Posted November 30, 2014 For some months I've been getting a strange combination of creaks squeaks groans and clicks from under my 90TD5; the problem was noticeable only at really-low speeds when going on or off the throttle at a couple of MPH. The problem went away if I drove with the diff locked, though sometimes I could provoke it to creak when parking: applying the handbrake then releasing the footbrake would occasionally produce a loud CLICK! I had visions of a bill for a new rear propshaft, assuming that after 100,000+ miles the UJs and/or the splined slip-joint were worn-beyond-repair. But - crawling around underneath, I noticed 'dusty' fretting-type rust-stains on the back of the handbrake-drum, radiating out from where the drum is sandwiched by the propshaft flange. Exploring the tightness of the four nuts holding the prop-flange to the drum, I managed to get 3 or 4 flats-worth of rotation on each. And now after a test-drive I'm happy that the creaky-clicky noises have gone! Must admit though, I'm minded to wait until spring and then strip the drum/drive-flange to check that there's no damage to the unthreaded parts of the studs from the repeated movement of the flange against them: surface damage to heavily loaded things like studs can produce 'stress-raisers' and result in catastrophic failure under load. Having seen what happens when a propshaft gets-loose at high speed [driver-fatality] I'm just a little paranoid. Quote Link to comment Share on other sites More sharing options...
western Posted November 30, 2014 Share Posted November 30, 2014 get in there as soon as possible, last thing you want is the front end of rear prop digging in the road it'll act like a pole vault & seeing the trans brake drum overtaking you on the road as it leaves you behind in a big heap of trouble. make sure the 2 drum to hub screws are intact too. Quote Link to comment Share on other sites More sharing options...
