Dr Bob Posted November 1, 2006 Share Posted November 1, 2006 Been told of a bulletin re TD5 heads cracking and leaking diesel into sump can anybody advise? Thanks Bob Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 1, 2006 Share Posted November 1, 2006 I don't know of a bulletin on the subject but it is correct to say that a cracking head could let diesel into the sump because the fuel rail is a machined cavity through the head. Quote Link to comment Share on other sites More sharing options...
BoatBuoy Posted November 1, 2006 Share Posted November 1, 2006 Been told of a bulletin re TD5 heads cracking and leaking diesel into sump can anybody advise? Thanks Bob Yes... get out the cheque book... Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted November 2, 2006 Share Posted November 2, 2006 While on the subject of TD5's. Anyone know what the designers had in mind to locate the big end bearings in the conrods to stop them spinning or moving sideways ? Bill. Quote Link to comment Share on other sites More sharing options...
imspanners Posted November 2, 2006 Share Posted November 2, 2006 If the injectors aren't seated properly or if one of the injector seals has split it will leak fuel into the oil system. Quote Link to comment Share on other sites More sharing options...
Dr Bob Posted November 2, 2006 Author Share Posted November 2, 2006 If the injectors aren't seated properly or if one of the injector seals has split it will leak fuel into the oil system. New injectors and seals fitted about 8 weeks ago when it first filled the sump,I will check I haven't nicked one fitting them but suspect the head,many thanks all comments wellcome. Regards Bob Quote Link to comment Share on other sites More sharing options...
