angie Posted November 3, 2006 Share Posted November 3, 2006 is there a gearbox sensor as i have steptronic gearbox and is getting stuck in gears but if turn on and off will go ok but then 2 mins later does it again Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 3, 2006 Share Posted November 3, 2006 there are a million sensors on the JATCO autobox and I don't think anybody really understands how they work, last time I looked it is a "sealed unit" basically no internal parts available from LR, and only seals etc for the outside, because it is SO complicated they won't let anybody else get into it ... I might be wrong but I don't think even the experts like Ashcrofts do rebuilds on them. Suggest you need to plug it into a dealer diagnostic system, it will speed the diagnosis up considerably! There will be an intermittent fault which will cause the gearbox to go into "limp home mode" but the fault could be gearbox, sensors or even the computer bus that links the whole lot together, if the signals are lost between modules it might provoke an electronic grump. Really not a DIY prospect I am afraid.... Quote Link to comment Share on other sites More sharing options...
white90 Posted November 3, 2006 Share Posted November 3, 2006 Ashcrofts Do rebuild/recon them they had recently purchased a very expensive machine to test run them after rebuilds when I visited a while ago. there is a speed sensor inside that packs up but as Stephen said not a home rebuild. the more I read on Freelanders the happier I am we got rid of Vals one Quote Link to comment Share on other sites More sharing options...
