paulnipper Posted January 29, 2015 Share Posted January 29, 2015 I need to test my injectors but there is no one near me to test them so I was wondering if I could remove them then loosen the injector hose nuts on the pump then fold them back then fit injecter and return line and then turn over the engine to c if thay are spraying ok and not leaking whould this work and be ok ???? dont want to damage anything I did do a search but found nothing .... thanks Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 29, 2015 Share Posted January 29, 2015 Sure. Just keep you fingers away from the spray. Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted January 29, 2015 Share Posted January 29, 2015 Is it not running correctly? What's the reason you want to test them? Be careful bending the pipes as they'll need to be reseated correctly when you refit the injectors. You may be able to remove the clips that hold the 4 injector pipes together and get away without bending them! Steve Quote Link to comment Share on other sites More sharing options...
paulnipper Posted January 29, 2015 Author Share Posted January 29, 2015 Thanks guys ive got lots of white / blue smoke on start up and just want to make sure its not the injectors b4 changing the valve stem seals ? Quote Link to comment Share on other sites More sharing options...
