minilander86 Posted January 30, 2015 Share Posted January 30, 2015 What's a good starter cb pack to get? Or what's a good cb radio??? Quote Link to comment Share on other sites More sharing options...
western Posted January 31, 2015 Share Posted January 31, 2015 Thunderpole do various 'starter packs' http://www.thunderpole.co.uk/cb-radio-packs.html Communications eleven have similar packs http://www.4x4cb.com/public/menu.cfm?Category=519&Browse=Products I've dealt with both before & they both know their stuff, you won't go wrong if you buy from either of these suppliers. Quote Link to comment Share on other sites More sharing options...
Boydie Posted February 1, 2015 Share Posted February 1, 2015 The small 5 watt GME 80 channel unit is fine, I've had mine for well over 5 years now and its never failed me once. The "kit" came complete with ariel and 90% of all the wiring that is needed, the only "accessory" I purchased outside of what was included in the kit being the microphone extension lead so that I could have the CB unit fitted in the roof light switch console and the mike located conveniently on the dashboard where the silly loose change slot used to be. I've found that the range with the supplied ariel is around 30 kilometres on flat ground and around 90 kilometres if I take the standard ariel off and replace it with a GME high gain unit. Clarity through the built-in speaker is exceptional, depending on the volume and squelch setting. Quote Link to comment Share on other sites More sharing options...
Radiotronics Posted November 24, 2015 Share Posted November 24, 2015 If you're installing it in a LR, take a look at the CBs that have a DIN mount option so that you can mount them in a spare DIN slot in the dash. Quote Link to comment Share on other sites More sharing options...
