Jocklandjohn Posted February 10, 2015 Share Posted February 10, 2015 I've got diesel welling up out of the bottom connection of the pipe from the rhs of the fuel filter (200tdi) to the lift pump. It's either the pipe joint itself or the lift pump which is a cheap and nasty thing but all the local garage had available when they fitted my fuel pump and realized my existing lift pump which I'd only recently put on ( a cheap one) was knackered. I'm swapping the cheap pump for a Delphi, but as the pipes (which have a banjo on top) are £20, I'm wondering is there a replaceable o ring on the pipe union where it mates with the lift pump? I recall seeing a black ring on the end when I fitted the last one but I'm not sure whether its a sealed on bit or whether it can be replaced. Anyone got any idea before I pull it apart? Quote Link to comment Share on other sites More sharing options...
western Posted February 10, 2015 Share Posted February 10, 2015 lift pump page 193 in http://www.retroanaconda.com/landrover/parts_books/110/3_engine_200TDI_300TDI_V8_p168-299.pdf fuel filter page 535 in http://www.retroanaconda.com/landrover/parts_books/110/6_vehicle_controls_brakes_fuel_air_p472-579.pdf no O ring seals that I ever seen on the lift pump to filter pipe connections, both a threaded to lift pump & end of pipe to pump faces form the seal. examine the nylon fuel pipe for hairline splits. Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted February 10, 2015 Author Share Posted February 10, 2015 Thanks Western. Appreciate those. Think I'll just renew the whole pipe, judging by the state of it, it looks like its been on there for a couple of decades so I guess it doesn't owe me anything! Quote Link to comment Share on other sites More sharing options...
