2dextas Posted February 22, 2015 Share Posted February 22, 2015 Hi my defender 110 200tdi makes a "phutting" noise but only apparent when under load - putting your foot down going up a hill for example.This is getting worse. No apparent affect on power or temp Obviously sounds like exhaust/manifold issue but i cant find it when stopped and just reving the engine. I have had a look and cant see or feel anything obvious. Any suggestions as to likely source and or how to replicate the" load" so i can find the source or any other tests etc regards mike Quote Link to comment Share on other sites More sharing options...
eds Posted February 22, 2015 Share Posted February 22, 2015 Mine did this too and it was blowing under load where the downpipe meets the exhaust manifold. Worth removing and reseating. Solved my same symptoms just yesterday coincidentally! :-) Quote Link to comment Share on other sites More sharing options...
2dextas Posted February 22, 2015 Author Share Posted February 22, 2015 thanks - i will poke about later and do that. after if not succesful i will have to just go through all i suppose unless theres any further bright ideas mike Quote Link to comment Share on other sites More sharing options...
Snagger Posted February 22, 2015 Share Posted February 22, 2015 That sounds like a head gasket or manifold gasket failure. Gas erosion could occur if left too long. I'd replace the manifold gasket first as it's cheapest and easiest, and then test it. If it continues, replace the head gasket as a matter of urgency. Quote Link to comment Share on other sites More sharing options...
2dextas Posted February 24, 2015 Author Share Posted February 24, 2015 well had a poke around and it seems to be just as Eds suggested just the down pipe junction, bit of fettling and it seems cured. Snagger - i was paranoid about head/manifold gasket initially hence request for tips on testing/finding but thanks for input - hopefully now resolved mike Quote Link to comment Share on other sites More sharing options...
2dextas Posted March 9, 2015 Author Share Posted March 9, 2015 hi spoke to soon - noise returned and seemed to get worse, more fiddling about head scratching then i saw a slight puuf from oner of thge injectyors out of corner of my eye - that seems to have been it - quick tighten preoblem solved. yess i should have arguably checked in firsrt place but hopefully this will help somebody else Quote Link to comment Share on other sites More sharing options...
