skauldy Posted March 5, 2015 Share Posted March 5, 2015 Hi folks, Pulled the sump off my auto box tonight to change the filter and found the below. Any ideas what it could be. Not familiar with autos. Quote Link to comment Share on other sites More sharing options...
Boydie Posted March 5, 2015 Share Posted March 5, 2015 It looks like normal gunk off the auto clutches - grey gooey sticky crud. This stuff is what messes up the centrifugal governor if it gets caught in it. From the look of it the oil and filter have not had a regular change. Run the car for another 1000 miles and give it another oil and filter change, it should be all flushed out by then, from there on change your oil and filter every 20,000 miles max. Quote Link to comment Share on other sites More sharing options...
skauldy Posted March 5, 2015 Author Share Posted March 5, 2015 Ah grand so it's not going to need a rebiuld or anything. Quote Link to comment Share on other sites More sharing options...
Boydie Posted March 29, 2015 Share Posted March 29, 2015 Sorry for not getting back to you sooner, no, you wont need to re-build the box. Just run it for the 1000 miles, then change the oil and filter again to ensure tat you have flushed out as much of the clutch crud as possible and from then every 20,000 miles. Keep an eye on the ATF fluid level, check it as often as you would the engine oil dipstick. To do this run the engine and gear box , park brake on, run the engine for a few minutes to ensure that auto gearbox pump is flowing the ATF through the oil cooler and then pop it through all the gears then leave it in neutral and then check the ATF level on the dip-stick, do not overfill ! Quote Link to comment Share on other sites More sharing options...
Sheffield Posted March 30, 2015 Share Posted March 30, 2015 I think it is easy to get a misleading reading on the dip stick because the oil tends to stay in the tube clinging to the surfaces if the stick is in place. I take the dip stick out before I start, and leave it out until I am ready to dip the level. This seems to make sure the oil clears from the tube properly and I get a true reading.. Quote Link to comment Share on other sites More sharing options...
skauldy Posted March 30, 2015 Author Share Posted March 30, 2015 Thanks guys. Just waiting on some money and will buy new filter and later output shaft. Shane Quote Link to comment Share on other sites More sharing options...
Boydie Posted March 30, 2015 Share Posted March 30, 2015 If the output shaft splines are worn then the problem is that the input gear in the transfer box hasn't been cross drilled to improve lubrication. There are several threads on the site to tell you how to do it. It's pointless replacing the output shaft if the input gear in the transfer box isn't cross drilled, it will only wear down again. Quote Link to comment Share on other sites More sharing options...
skauldy Posted March 31, 2015 Author Share Posted March 31, 2015 The transfer box is from a newer model and has the cross drilled input gear. Hence why I'm changing the zf output shaft as it need to be longer. Quote Link to comment Share on other sites More sharing options...
Boydie Posted March 31, 2015 Share Posted March 31, 2015 It will give you chance to clean out any gunk from the governor Quote Link to comment Share on other sites More sharing options...
