Forest Eyes Posted March 21, 2015 Share Posted March 21, 2015 Hi guys, I have a Defender 90 that is experiencing repeated front prop/UJ wear/failure and need to know if it has been lifted or not. Is there a simple measurement I can take from say the axle to somewhere that will tell me this? If it has been lifted, it is not my much and I don't think enough to be causing the issue, but I could do with knowing one way or the other. Cheers Quote Link to comment Share on other sites More sharing options...
stuck Posted March 21, 2015 Share Posted March 21, 2015 Measure the distance between the floor & a fixed point such as the underside of the front bumper (assuming the bumper is standard) & post the height. Don't forget to include tyre size & rim diameter 1 Quote Link to comment Share on other sites More sharing options...
stuck Posted March 21, 2015 Share Posted March 21, 2015 Wouldn't go amiss to post what make UJ's you are using. Let me guess... Quote Link to comment Share on other sites More sharing options...
Paul Woodward Posted March 21, 2015 Share Posted March 21, 2015 The best way is to measure the length of the springs with the truck sat on level ground. The front spring should be approx 260mm long and the rear 300mm long, measured seat to seat, for a std height. 2 Quote Link to comment Share on other sites More sharing options...
Forest Eyes Posted March 21, 2015 Author Share Posted March 21, 2015 Wouldn't go amiss to post what make UJ's you are using. Let me guess... Thanks for your help; they are not Britpart, but are make unknown as were bought in by the garage. Quote Link to comment Share on other sites More sharing options...
Forest Eyes Posted March 21, 2015 Author Share Posted March 21, 2015 The best way is to measure the length of the springs with the truck sat on level ground. The front spring should be approx 260mm long and the rear 300mm long, measured seat to seat, for a std height. Thanks Paul, I wondered if this was an option; I will try this tomorrow. Quote Link to comment Share on other sites More sharing options...
Forest Eyes Posted March 21, 2015 Author Share Posted March 21, 2015 Measure the distance between the floor & a fixed point such as the underside of the front bumper (assuming the bumper is standard) & post the height. Don't forget to include tyre size & rim diameter Everything else is standard as far as I know. It looks lifted as it has diddy 225's on it, but the garage think the springs are poss bigger than standard. I will get my tape measure out tomorrow. Quote Link to comment Share on other sites More sharing options...
Forest Eyes Posted April 2, 2015 Author Share Posted April 2, 2015 Measure the distance between the floor & a fixed point such as the underside of the front bumper (assuming the bumper is standard) & post the height. Don't forget to include tyre size & rim diameter Hiya, finally got there! The bumper is c. 52/53 cm from the deck, measured to the underside. Tyres are 225/75/R16 Quote Link to comment Share on other sites More sharing options...
Forest Eyes Posted April 2, 2015 Author Share Posted April 2, 2015 The best way is to measure the length of the springs with the truck sat on level ground. The front spring should be approx 260mm long and the rear 300mm long, measured seat to seat, for a std height. I measured the springs from the top to the bottom, so hopefully that is what you meant. The front was more like 275280 and the rear 300. Got a pick of the front spring with tape measure, how do I upload a pic, I can't seem to work it out? I have nothing in 'My media' and the image button asks for a URL. Quote Link to comment Share on other sites More sharing options...
