JeffR Posted May 28, 2015 Share Posted May 28, 2015 OK so having (probably) sorted out the mirror electrics for fitting 300 tdi doors to a 200 tdi now my problem is the heated rear screen has ceased to function. well lets be honest the bugger has never worked. So my multimeter tells me that electricery is getting to the (intact) fuse, the screen element is continuos and intact and the switch on the instate binnacle works. The only thing left is the bloody relay, but where on earth is it situated? Can't find the bugger in the footwells, so where in the vehicle did Landrover hide it? This is doing my head in.... Quote Link to comment Share on other sites More sharing options...
teabag Posted May 29, 2015 Share Posted May 29, 2015 When it left the factory it was behind the drivers kick panel, it the same relay that's used for both mirror heaters. Quote Link to comment Share on other sites More sharing options...
JeffR Posted May 31, 2015 Author Share Posted May 31, 2015 When it left the factory it was behind the drivers kick panel, it the same relay that's used for both mirror heaters. Finally found the bugger... Quote Link to comment Share on other sites More sharing options...
