Tractorman Posted July 15, 2015 Share Posted July 15, 2015 I spent a silly amount of time replacing the broken lock spring in my disco 300tdi, got it all back together, eventually in the right order... and it still doesn't work. Everything works fine but you still need to put turn the key/lift the button to open the door, just like when the spring has broken. I stripped off the door card again but can't see any faults, just that the mech doesn't pull down far enough. Can't get an mot until the door lock works as it should... anyone any ideas?? Quote Link to comment Share on other sites More sharing options...
JeffR Posted July 16, 2015 Share Posted July 16, 2015 Had a similar problem, you can adjust the button and various other rods/linkages, but it is a thankless time consuming task, or you can slightly bend the rod on which the button is screwed so that friction holds the button up - a bodge, but it works. Quote Link to comment Share on other sites More sharing options...
Tractorman Posted July 16, 2015 Author Share Posted July 16, 2015 I thought about bending the rods but then I might make it worse..! I wondered about trying to add another spring to pull down on the latch arms but would really like to work out why its not right. Its only out by a few mm but seems that's all it takes Quote Link to comment Share on other sites More sharing options...
