nenook Posted October 2, 2015 Share Posted October 2, 2015 Hi I'm new on here , from Stafford I've got 1998 300 tdi , I've got a + 2 lift kit to fit , I've just bought 245/75/16 cooper maxx 's I'm not looking at going mad , I've got + 2 SS flexy hoses to fit , do I need our else , I've heard of radius arms ,? Any help welcomed Thank you Nenook Quote Link to comment Share on other sites More sharing options...
Boydie Posted October 6, 2015 Share Posted October 6, 2015 If you are only lifting it 2" you don't need special offset bushes in the front radius arms. I would advise you fit a longer rear brake flexible hose however, the fronts should be okay. Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted October 6, 2015 Share Posted October 6, 2015 I run 245/75's I have 1" of lift on the front - with OE HD springs and damped with Raw 4x4 shocks (soon to be Bilstein B6) I was running OE HD springs on the back with 24mm of additional spacer (Gwyn Lewis) and the 25mm of the spring. I changed to OME 764 Medium's and 12mm of lift - so a total of 52mm of lift. However as the OME springs are better quality wire and thinner, they don't get coil bound quite as soon as the OE HD's. This has resulted in the need for a Camel Cut... I run zero offset 7x16 modular's Quote Link to comment Share on other sites More sharing options...
