squi5566 Posted February 13, 2016 Share Posted February 13, 2016 Hello all, i recently picked up a range rover 200tdi factory original, been standing 2 years, its a 1993, needs some tlc, but everything works, and every little part is on it, and its started so easy, and clean, has 184000 miles, thing is,i got under it and noticed the front prop was missing, i bought it without seeing first, didnt have time. anyway can anyone tell me which is the right prop to buy for it, nothing on the web, makes it very clear, a friend gave me one from a 92 petrol se, would that be the same, as the the one that should be on it, length is the same, from the flange to flange, also while im here, if you grab the flange on the rear diff, vehicle on ground, prop off, ive got about 2inches of knocking free play (backlash is it)?, is that too much?? and can it be adjusted, or should i just get another diff, thanks in advance for advice. Quote Link to comment Share on other sites More sharing options...
Tanis8472 Posted November 3, 2017 Share Posted November 3, 2017 Old I know, but no petrol and diesel have different part numbers Ftc122 for diesel FRC9542 for petrol Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted November 4, 2017 Share Posted November 4, 2017 But... There's a very good chance the prop was removed because the viscous coupling in the centre diff is seized. So bolt the prop on and check - although I'm sure this is all done and dusted long ago. Quote Link to comment Share on other sites More sharing options...
