ajh Posted February 21, 2016 Share Posted February 21, 2016 Anyone know what factory spec is on the length of the brake booster rod? Somewhat urgent. Quote Link to comment Share on other sites More sharing options...
western Posted February 21, 2016 Share Posted February 21, 2016 no idea about the factory set length, but when I did my rear disc conversion on my 110, I had to adjust the servo [brake booster] pushrod length as there was no clearance with brakes off, so moved the master cylinder [MC] forward, unlocked the pushrod & adjusted it, then in the brake cylinder piston recess placed some bluetac [poster hanging putty] pushed the MC back in place so it sat down tight onto the servo, moved it forward again, carefully extracted the bluetac, cut it in half then measured it to find out the clearance, I eventually settled on 1.7mm clearance, that solved my rear brake dragging problem, Quote Link to comment Share on other sites More sharing options...
qwakers Posted February 22, 2016 Share Posted February 22, 2016 good info there western, i will get on with sorting mine now i know... 1 Quote Link to comment Share on other sites More sharing options...
