TD5 starting problem related to fuel level
Hi all,
I have a 2000 defender td5 having the following problem. When its full, no problem what so ever, perfect starting cold and hot and runs like a breeze. But, whenever the fuel level is less than full it becomes difficult to get it started, and when its around 1/4 its almost impossible to start. Removed the fuel pump and and looked for any crack in the hoses, didn't find any.
Any one familiar with such a problem or suggestions?
Thanks,
Omar
I'd suggest that the low pressure pump isn't working properly, when the tank is full it's aided by gravity but as the tank empties it's struggling to pump the fuel "up hill" to the fuel filter unit.
You may well hear a different pump sound when it's full of fuel versus when it's low on fuel.
The only solution is to change the pump unit if it is the pump.
Thanks for your replies,
Removed the tank and found a faulty non return valve in the middle of LP feed line, blocked it then started it for couple of minutes was ok. Tried to start again for a test drive and it was immobilized! Will start another thread fir that.
  • 2 weeks later...
