Anderzander Posted March 12, 2016 Share Posted March 12, 2016 I've swapped in a different transferbox and now have a bit of vibration between 40 and 50 - which I remember Les on here saying can be caused by the output shaft bearings. I'm no expert in what to look for - but when I fitted it I couldn't feel any play? What would I be looking for, in out or side to side, or could the bearing wear and not be felt at the shaft? If I run it with a prop missing, and it is the bearing, would the vibration go? If I'm taking the prop off to check that may the simple answer to confirm it if it would. Any help gratefully received ! Quote Link to comment Share on other sites More sharing options...
marktdi Posted March 15, 2016 Share Posted March 15, 2016 If you remove each prop in turn and go for a short drive this should tell you were the prob is Quote Link to comment Share on other sites More sharing options...
Anderzander Posted March 15, 2016 Author Share Posted March 15, 2016 Thanks Mark - I'll give it a try. Quote Link to comment Share on other sites More sharing options...
