Ex Member Posted November 24, 2006 Author Share Posted November 24, 2006 I think it will be in the same spot as the current setup. It is -20C out right now , so crawling around under the 90 is not on my list of enjoyable activities. Forecasting a HIGH of -27 C on Monday . It was +15C last week...... Anyway, back to topic, I ordered the pulley. The parts book also says that I need the newer model fan to match the newer model pulley?? I ordered that as well as it was only 11 quid. I think I have just sold the old motor, so it is all coming together and I should have it in by Christmas. Quote Link to comment Share on other sites More sharing options...
western Posted November 24, 2006 Share Posted November 24, 2006 I think the fan blades sit slightly further forward so they don't interfere with the air con pump belt, can't see any other reason to change the fan. best wishes for a successful swap. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted March 6, 2007 Author Share Posted March 6, 2007 BTW, the engine is in and it is running well so far. The swap went well. Around 12 hours work or so. The pulley mentioned above (ERR3093) is spot on and my air compressor can just mount straight back up where it used to be once I drill and tap the air con mounting holes. Why LR can't do this at the factory is beyond me... The new fan blade is the same as the old one... More spare parts. Quote Link to comment Share on other sites More sharing options...
DonFromCanada Posted May 17, 2010 Share Posted May 17, 2010 THIS is how Les Brock did it, and indeed how the factory AC setup works. Any link to this article anymore? the link in this post is missing.... Would really like to try and find a three groove pulley for adding aircon to a 200tdi - need to find a bracket and belt for it as well. Quote Link to comment Share on other sites More sharing options...
DonFromCanada Posted May 17, 2010 Share Posted May 17, 2010 BTW, the engine is in and it is running well so far. The swap went well. Around 12 hours work or so. The pulley mentioned above (ERR3093) is spot on and my air compressor can just mount straight back up where it used to be once I drill and tap the air con mounting holes. Why LR can't do this at the factory is beyond me... The new fan blade is the same as the old one... More spare parts. Wondering if I could bother you for some advice? I'm looking to mount up a Sanden 508 style compressor to add Aircon to my 200tdi (mounted into a Series 2A Dormobile) I think I need an aircon bracket, 3-groove crank pulley, and a belt? Thanks! Don Quote Link to comment Share on other sites More sharing options...
