margina Posted May 16, 2016 Share Posted May 16, 2016 hello i'm from Bulgaria i need help to put m52b28 from bmw to my defender 90.My defender now is with 2.0 16v MPI engine.I read Andrew's Defender 90 3.0i Project but have alot of questions.Fist i wont to know what kind of gearbox and from what kind of rover i need my is R380 from 2.0 16v MPI.I read that i need a clutch housing adaptor from p38 2.5 TDS.I copy engine mounts from the other theme.my email is margaritdenchev@gmail.com i need every information about how to get engine and gaerbox together - flywheel, clutch housing adaptor, clutch ect. i hope user Adam001 to help me pls Quote Link to comment Share on other sites More sharing options...
tacr2man Posted May 17, 2016 Share Posted May 17, 2016 You will need p38 rangerover bell housing and r 380 input shaft. I suggest that you try South African Landy forum for what clutch/flywheel is used , as 2.8 i was built in defender sold in ZA . Quote Link to comment Share on other sites More sharing options...
Adam001 Posted July 8, 2016 Share Posted July 8, 2016 Hi, sorry missed this, got your PM. Not familiar with the 2.0 MPI but you would need either A) P38 input shaft in a Defender R380 gearbox with a P38 2.5DSE bellhousing or... B) Defender R380 gearbox with the specific M52B28 defender bellhousing Option A is much easier to get hold of but the engine will be inclined by approximately 11 degrees from nominal. Option B is the same as factory fit but that bellhousing is extremely hard to get hold of. Both options take the P38 dual mass flywheel and clutch arrangement. I fitted mine using option A with the gearbox on 200tdi mounts and custom engine brackets onto the factory 200tdi chassis mounts, I did not weld the chassis in any way. If you have a 300tdi/TD5 base chassis then the engine sits slightly further back but I believe is just as straightforward, but the incline with option A may then become a problem. South african cars were based off the 300tdi/TD5 chassis. In general though a good read of my build thread and Andrews will give you most of the knowledge straight away. Good luck. 1 Quote Link to comment Share on other sites More sharing options...
