bodumatau Posted August 3, 2016 Share Posted August 3, 2016 Maybe I am just being thick or maybe this is the wrong part but my transfer box lever is so close to the gear lever that when I am in Low and select 2nd, 4th or reverse it knocks the trf box out of gear... here is a pic of the trf box in Low and the gear lever in neutral does anyone know what is wrong or how to fix this? (before I start tearing the bits apart) Quote Link to comment Share on other sites More sharing options...
qwakers Posted August 3, 2016 Share Posted August 3, 2016 looks bent, heat the shaft up and bend it the other way Quote Link to comment Share on other sites More sharing options...
bodumatau Posted August 3, 2016 Author Share Posted August 3, 2016 yes that was my plan (my plans usually involve big hammers or red hot metal) so I was wondering if there was a more.....ahm.....refined solution before I grab the sledge hammer Quote Link to comment Share on other sites More sharing options...
qwakers Posted August 3, 2016 Share Posted August 3, 2016 no need for a slege hammer, take the knob off the top and use a large ring spanner as a lever to bend it. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted August 3, 2016 Share Posted August 3, 2016 Remove the gaiter and tunnel and the linkage is staring at you. Slide the collar off the spine, move the lever back a tad and put the collar back on. Quote Link to comment Share on other sites More sharing options...
bodumatau Posted August 5, 2016 Author Share Posted August 5, 2016 thanks Vulcan, thought there was a cleverer solution than me hitting it with a Sledge hammer....., be trying that. think I got it wrong in my rush to get my trf box back in when I replaced it.....or just stupidly copied the same position of the old trf box lever without thinking it thru..... no pills for stupid.... Quote Link to comment Share on other sites More sharing options...
