Yolandi Posted October 8, 2016 Share Posted October 8, 2016 Hi all, changed the t box rear prop bolts today as the old ones were amazingly damaged, anyway i recently had the assosiated pinion seal replaced there and when i took the flange off (behind the brake drum) it quickly started leaking oil until i replaced the flange and tightened it down, iv got a slow leak from this area anyway but am wondering if having oil pour out when you remove the flange is normal? Quote Link to comment Share on other sites More sharing options...
ericobrave Posted October 8, 2016 Share Posted October 8, 2016 Yes, in my case, both my Defenders do this when the flange is pulled off. 1 Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted October 8, 2016 Share Posted October 8, 2016 Yes. The flange runs in the oil seal and the oil level is some what higher than that. Quote Link to comment Share on other sites More sharing options...
