bombx3 Posted October 4, 2009 Share Posted October 4, 2009 hi on my TD5 90 2004 model i just noticed when i start her it smokes (blue and skinks a lot ) then after a minute or so nothing except a little puff off black smoke on full chat Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 4, 2009 Share Posted October 4, 2009 Could be something like oil seeping past the valve stem seals, if it clears and doesn't come back How long do you need to leave it sitting before it happens on startup? minutes, or overnight? Quote Link to comment Share on other sites More sharing options...
bombx3 Posted October 4, 2009 Author Share Posted October 4, 2009 Could be something like oil seeping past the valve stem seals, if it clears and doesn't come back How long do you need to leave it sitting before it happens on startup? minutes, or overnight? it only does it when cold or should i say while the revs are higher than normal like its on fast idle this goes after a minute or so then perfect.it doesnt smell oily more like haft burnt deisel Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 4, 2009 Share Posted October 4, 2009 Have you had any problems with non-start or the engine cutting out? One possibility might be fuel leaking into the cylinders either from a dud injector or past the copper washers that seal the base of the injector, though the latter is more likely to be accompanied by other problems i.e. non start. Quote Link to comment Share on other sites More sharing options...
bombx3 Posted October 5, 2009 Author Share Posted October 5, 2009 Have you had any problems with non-start or the engine cutting out? One possibility might be fuel leaking into the cylinders either from a dud injector or past the copper washers that seal the base of the injector, though the latter is more likely to be accompanied by other problems i.e. non start. Hi ,it starts fine ,today no smoke but when it does it runs a bit lumpy till it clears Quote Link to comment Share on other sites More sharing options...
lronly Posted October 27, 2009 Share Posted October 27, 2009 Hi did you find a remedy for this problem? I have 3 cars doing the same thing and i have also taken the head off on one of them and changed the injectors and seals and copper seals too all was fine but problem still there! Help please Quote Link to comment Share on other sites More sharing options...
landy andy. Posted October 28, 2009 Share Posted October 28, 2009 Mine was solved by fitting a new MAF, Done by Porny at IRB developments, even tho the diagnostics did not say there was a problem. Andy Quote Link to comment Share on other sites More sharing options...
