tweetyduck Posted March 15, 2010 Share Posted March 15, 2010 I've read that when using the HD track rod the stearing dampner isn't required. I'd obviously like to keep mine on. Has anyone fitted the Bearmach BA220 and can tell me if i can leave the stearing dampner fitted? Thanks Catalog Wording>>>> """"Features: No steering damper required. The heavy steel takes stress off the ball joints. Rods and joints last longer."""" Quote Link to comment Share on other sites More sharing options...
Aragorn Posted March 15, 2010 Share Posted March 15, 2010 the damper is there to make driving on rough terrain easier, and to stop large jolts on the steering transferring thru the column to your hands... I cant see why it would be unneccesary with a HD Track Rod? Surely fitting a HD rod means your more likely to be doing offroading work? Its arguably unneccesary if your driving solely on tarmac though. Quote Link to comment Share on other sites More sharing options...
dantd5 Posted March 15, 2010 Share Posted March 15, 2010 My ignorance kicks me to ask why one will omit a steering damper? What do you fill that gap with? Quote Link to comment Share on other sites More sharing options...
Orange Posted March 15, 2010 Share Posted March 15, 2010 The steering damper fits to the drop arm adapter to a point on the near-side chassis, so it doesn't matter what steering bars you run, it can still be fitted. (Unless you change the steering drop-arm (from the steering box) to the Discovery type) I have the Bearmach HD Drag Link and Tie Rod and run a delphi steering damper in the usual Defender position without any issues whatsoever. Quote Link to comment Share on other sites More sharing options...
Orange Posted March 15, 2010 Share Posted March 15, 2010 Dan - you can run without a steering damper, in fact some challenge competitors do. It's one less thing to damage. The downside is that driving the vehicle on the road becomes a more active experience where you will feel every knock, bump and pothole. I ran my old Range Rover without one for a while (while I was waiting for a conversion kit to move it to the Defender position) and it was amazing what difference it made. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted March 15, 2010 Author Share Posted March 15, 2010 As long as it will fit with the current dampner and "end bit" then i'll order one. Thanks All and Thanks Orange as if you have that one (same model) i'm assured it will be OK. TA Quote Link to comment Share on other sites More sharing options...
dantd5 Posted March 15, 2010 Share Posted March 15, 2010 Dan - you can run without a steering damper, in fact some challenge competitors do. It's one less thing to damage. The downside is that driving the vehicle on the road becomes a more active experience where you will feel every knock, bump and pothole. I ran my old Range Rover without one for a while (while I was waiting for a conversion kit to move it to the Defender position) and it was amazing what difference it made. Ahaa Orange.. Something learnt for the day!! Thanks..... Quote Link to comment Share on other sites More sharing options...
Litch Posted March 15, 2010 Share Posted March 15, 2010 Steering damper fits ok with solid bars as unlike on Series vehicles, the damper attached to the bracket and not the bar itself. I run this setup myself but bars came from Green Oval. Quote Link to comment Share on other sites More sharing options...
