Escape Posted December 12, 2011 Share Posted December 12, 2011 Having tried all I can think of, I hope to get some good advice here to help a friend solve a bad and worsening starting problem: Car is a 2003 Defender 90 TD5, with about 200k km on it. Since some time, it's having irregular starting problems. Both cold and hot, but only every now and then. We have already replaced (for new or known good items) the following:µ - glowplugs - injector washers and O-rings - injector wiring loom (some oil in the cables, cleaned thoroughly) - fuel pressure regulator (because of a small leak) - fuel pump (unnecessary, but done by a garage ) - fuel filter, airbleed valve and injector filter (behind the FPR) - checked tank for sludge - CKP (swapped from mine) - MAF (swapped from mine) - ECU (swapped from mine) - temperature sensor (swapped from mine) - no fault codes present Early this year the problems disappeared for a while, after getting stuck nose down in a ditch. Lately, they have returned worse then ever. Not only is the car hard to start at times, it will also tend to stall at idle, typically after about 20 min of driving. Throttle respons and power are good otherwise. It seems to be starving for fuel at times, but only at idle or when starting. Is there anything else to check or try before I swap the injectors? Thanks, Filip Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted December 12, 2011 Share Posted December 12, 2011 Having major starting issues on mine at the moment, but mines sucking air from somewhere. have you checked the starter motor? evidently the starter can cause issues to starting and fuelling because the earth path runs through it to the ecu for the injectors! they (starter motors) can apparantly arc inside sending random signals to the ecu. steve Quote Link to comment Share on other sites More sharing options...
Escape Posted December 12, 2011 Author Share Posted December 12, 2011 Thx for the input Steve, hadn't heard about that yet, but the starter is easy enough to swap and find out. Will keep you posted. Quote Link to comment Share on other sites More sharing options...
101sean Posted December 13, 2011 Share Posted December 13, 2011 A dodgy starter will upset the signal from the crank sensor, as ORT says, the arcing sends dirty spikes up the loom. A dodgy CP sensor is also the only one that will kill a TD5, none of the others stop it running Quote Link to comment Share on other sites More sharing options...
Escape Posted December 16, 2011 Author Share Posted December 16, 2011 As said, we already swapped the CP sensor, no change in the 'bad' car, and mine is none the worse for it either. Last thing we tried was swapping the accelerator pedal, no change. What's puzzling me the most, you can almost set your watch to it: have it in the Shop, change something, clean something or just look at it long enough and will start fine. But after exactly 20 min it will stall and refuse to restart... Quote Link to comment Share on other sites More sharing options...
Escape Posted January 4, 2012 Author Share Posted January 4, 2012 Update, we got the running and (touching wood) it seems to keep running this time. We swapped the injectors, inertia switch, fuel filter housing, blew through all the fuel lines and added 2 cans of diesel injector cleaner. After a bit of hesitation it started, and has been running weel and restarting reasonably ever since. Strange thing is, we swapped most of the components with my own Defender, and (once I remembered was told to reconnect the CKP) that also starts and runs fine. Important thing is we seem to have solved it, but still curious about the exact cause... Filip Quote Link to comment Share on other sites More sharing options...
