Marco Posted September 2, 2008 Share Posted September 2, 2008 Hi, Jsut replaced the rubber engine mounts on my 200Tdi and right now I do have a bad vibration. Expect them maybe to be more stiff? And are there any alternatives? Or maybe the engine is sitting a little higher now touching the body? Due to the rainy weather I can not check that one right now :-( Any suggestions? Thanks Marco Quote Link to comment Share on other sites More sharing options...
western Posted September 2, 2008 Share Posted September 2, 2008 are the rubber mounts Genuine LR parts or from another supplier ? what was wrong with the old mounts ? soft or split haven't had any excess vibration from my 200TDi's genuine mounts, maybe they are to soft [non orignial] and allowing excess movement Quote Link to comment Share on other sites More sharing options...
Marco Posted September 2, 2008 Author Share Posted September 2, 2008 are the rubber mounts Genuine LR parts or from another supplier ? Non genuine, not sure about the brand though. They are not Britpart. what was wrong with the old mounts ? soft or splithaven't had any excess vibration from my 200TDi's genuine mounts, maybe they are to soft [non orignial] and allowing excess movement They are a bit deformed + oily and with upcoming MOT I decided to replace them... right now I do regret! No not soft, could they be to stiff? Quote Link to comment Share on other sites More sharing options...
western Posted September 2, 2008 Share Posted September 2, 2008 new genuine are quite stiff from new, so doubt the ones you have fitted would be any stiffer, but suppose it's possible, have you looked at the gearbox rubber mounts as well, these are the same as the engine rubber mounts & if soft/worn or seperated from the metal baclplates plates could cause a vibration. Quote Link to comment Share on other sites More sharing options...
Marco Posted September 2, 2008 Author Share Posted September 2, 2008 new genuine are quite stiff from new, so doubt the ones you have fitted would be any stiffer, but suppose it's possible, have you looked at the gearbox rubber mounts as well, these are the same as the engine rubber mounts & if soft/worn or seperated from the metal baclplates plates could cause a vibration. OK than it has to be something else, gearbox mounts have been replaced last year and should be fine, will have to check. Maybe it's just something basic like touching the body somewhere. Quote Link to comment Share on other sites More sharing options...
Marco Posted September 3, 2008 Author Share Posted September 3, 2008 I've now fitted ANR1808 / MRP2227 (turbo diesel / 4cyl.) made by Karsons... Looking at the parts list I do need ANR2488 for 200Tdi.... Main question are they the same / what's the difference? Can not find an image of both on the web. Tried to move the engine a bit but so far no change, the anoying vibrating/drumming noise is still there. Cheers Marco Quote Link to comment Share on other sites More sharing options...
Matt Neale Posted September 3, 2008 Share Posted September 3, 2008 I've now fitted ANR1808 / MRP2227 (turbo diesel / 4cyl.) made by Karsons... Looking at the parts list I do need ANR2488 for 200Tdi.... Main question are they the same / what's the difference? Can not find an image of both on the web.Tried to move the engine a bit but so far no change, the anoying vibrating/drumming noise is still there. Cheers Marco Marco, When I changed my engine from a TD to a 200 Tdi, I fitted genuine part engine rubbers as specified for the Tdi. I had much the same result as you've found - lots of transmitted vibration. I thought I'd done something wrong with the install - I checked everything - I must have re-hung the exhaust a dozen times and checked and adjusted everything else. In the end I fitted another set of engine rubbers - ones I had on the shelf that I'd bought a couple of years earlier and as spec'd for a Range Rover V8. They've been on there for about 2 years now no problem. The vibration is minimal and I'm well pleased. Bottom line - try a different set of rubbers - it doesn't take long to change them and it could make a big difference. Matt Quote Link to comment Share on other sites More sharing options...
dave88sw Posted September 3, 2008 Share Posted September 3, 2008 i was once told by a very knowledgeable and experienced mechanic that if you soak new engine rubbers in a bucket of used engine oil over night, they soften just enough to stop any juddering. could be worth a try Quote Link to comment Share on other sites More sharing options...
western Posted September 3, 2008 Share Posted September 3, 2008 I've now fitted ANR1808 / MRP2227 (turbo diesel / 4cyl.) made by Karsons... Looking at the parts list I do need ANR2488 for 200Tdi.... Main question are they the same / what's the difference? Can not find an image of both on the web.Tried to move the engine a bit but so far no change, the anoying vibrating/drumming noise is still there. Cheers Marco ANR1808 are correct for the 200Tdi engine [got these in my 110] TD uses ANR1808 from chassis JA920703 or NRC9560 upto chassis JA920702 which is the same for the 2.5n/a diesel engine & the 2.5 petrol uses ANR1808. so my paper genuine parts book [1987 on 110] tells me Quote Link to comment Share on other sites More sharing options...
Marco Posted September 3, 2008 Author Share Posted September 3, 2008 Thanks for the feedback guys! Will probably refit the old ones (for the time being), have to dig them up out of the garbage bin first! Cheers, Marco Quote Link to comment Share on other sites More sharing options...
Marco Posted September 4, 2008 Author Share Posted September 4, 2008 Update on this one, just replaced the new mounts with the ones out of the dust bin. And guess what, the vibration has gone. Not a real solution but for the time being it's OK. Will buy another brand (not Karsons) and fit those at a later stage. Cheers Marco Quote Link to comment Share on other sites More sharing options...
Lars L Posted September 4, 2008 Share Posted September 4, 2008 And you have made me order a pair for RRC V8... Quote Link to comment Share on other sites More sharing options...
