Does a v8 P38's power steering pump produce more flow / pressure t
zim
As per title,
I've got a challenge next weekend and my zf74 is pretty much kaput ! I'm getting about 500psi out of it (testing it against it's pressure relief valve).
So....will a p38's v8 pump be the same or more than a RRC v8's ?
Reading rave the p38 seems to go up to about 1500ish but the rrc to about 1100.
Cheers
G
G,
I have a P38 4.0l in my RRC, P38 pump running the stock RRC 4-bolt box, after the engine swap I believe the steering was MARGINALLY lighter, this may not help at all, but if it doesn, great :)
Oh, and the standard RRC pipes bolt straight up to it.
Cheers.
The zf74 has an m16x1.5 thread output from what i can see.This is the same as the rrc pump i fiddled with quickly last night.
Dan, i don't have a dirty td5 so can't check :P
G
p.s. Just noticed, the title i wrote in the box hasn't all been displayed - it's cut the last few letters off.
Tested a couple vehicles today, with a closed output - just the gauge :
P38 4.6 v8 zf pump - 1,500psi
RRC 3.9 v8, with the cylinder style pump - 800-900psi
So i'll fit a p38's pump tomorrow :)
