Theviper1987 Posted November 19, 2015 Share Posted November 19, 2015 I no gwyn Lewis makes a twin alternator bracket for the serp belt v8's. But he doesn't make anything for the v belt set up. Anyone ever made one or no where I can buy one? Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted November 19, 2015 Share Posted November 19, 2015 Do you have an ac compressor? If not you might be able to adapt that bracket and pulleys. 1 Quote Link to comment Share on other sites More sharing options...
taz90 Posted November 20, 2015 Share Posted November 20, 2015 my alternator bracket was a small triangle off the pump and a larger plate mounted to the head and the third fixing was a slider mounted at the bottom of the engine. the alternator is a LRA495 it needs to have a small rectifier on the back as rooms tight. will try and get some better photos over the weekend Quote Link to comment Share on other sites More sharing options...
Theviper1987 Posted November 20, 2015 Author Share Posted November 20, 2015 Thanks. More pictures would be very help full. Quote Link to comment Share on other sites More sharing options...
iomlt Posted November 20, 2015 Share Posted November 20, 2015 get a mount from a engine that had the alternator on the other side as standard. it will bolt up and you have the perfect mount then . Quote Link to comment Share on other sites More sharing options...
Theviper1987 Posted November 20, 2015 Author Share Posted November 20, 2015 Any ideas what had? Quote Link to comment Share on other sites More sharing options...
zim Posted November 24, 2015 Share Posted November 24, 2015 What's wrong with just using a bracket from an early carb'd v8 that puts the alt on the driver's side. With a bit of fetelling lines up with the AC pulley. G Quote Link to comment Share on other sites More sharing options...
Theviper1987 Posted November 24, 2015 Author Share Posted November 24, 2015 Thanks mate I'll give it a go Quote Link to comment Share on other sites More sharing options...
