ex military 90 wiring
Quick thing
1. does anyone have the wiring diagram for an 86 military def 90-with the lights still on the lucas switch on the centre of the dash. Ive bodged a few things, but it'd make life a damn site easier
2. does anyone have any pics of their interiors/advice on rewiring. Ive just got a new bumper with twin spot and winch mounts (just need the winch!) now seems a good time to re jig it all. Ive already got a double battery system, so that isnt a problem. I saw a guy when I was out last week who had it all mounted on a ali dash plate (winch, lights, emergancy cut out, etc)
just curious as to everyones ideas and takes on what is probably a common situation
apologies if this thread has come up before.
Guest diesel_jim
Quick thing
PM me your email address, i'll fling some over.
cheers. How easy is it to rewire and fit a new style fusebox. Basically Im overhauling my landy (slowly and on a very tight budget). realistically, I need to refuse everything, probably re wire alot of things, run a few accesory wires.
Im no expert- said in a different topic i know a bit about electrictronics, and im not bad at wiring. Just not sure where to start and what approach to take!
thanks
Guest WALFY
On m 90 I changed the old style glass fuses for newer style blade fuses. I am absolutely pants and wiring and I managed it. Cost about 30 quid tops to do it all. All done with gen parts as well
thanks
The later blade type fusebox is available from Land Rover as a replacement for the older glass fuse type -
  • Fuseblock = PRC4826 - £4.52
  • Connector to fit 0.5 - 1.0mm2 cable = STC4034 - £3.65
  • Connector to fit 1.1 - 2.0mm2 cable = STC4035 - £4.98
  • Connector to fit 2.5 - 3.0mm2 cable = STC4036 - £0.61
Prices are Retail inc. VAT from Feb. 2008 Microcat
Microcat doesn't specify the quantity of connectors supplied for the price shown.
Paul.
Guest WALFY
Paul.
I do remember the brass connectors being expensive. IIRC that price is EACH :( . I went and saw the sparkys at work and blagged some.
is there any point me relaying all the cables? or is that just a waste of time. I dont want to have to come back and do it later, and if im having to lay one cable i may aswell do them all-i just got a new twin spot front bull bar, and im going to have to lay cable for them, am i not?
cheers for the prices. I might have to speak to mate in the REME....
  • 4 years later...
Paul.
An update to this thread:
There's a seller on eBay, selling the Lucas-RISTS 20-Way Blade Fusebox & Terminals.
This is PRC4826 - with 40 x terminals, for only - £6.50
http://www.ebay.co.uk/itm/140844488407
