Td5 error codes
tonyalbers
My nanocom gave me this output from my D2:
The TD5 ecu contain the following faults:
FAULT 08-01 air conditioning fan drive over temperature LOGGED
FAULT 08-02 fuel pump drive over temperature LOGGED
FAULT 08-03 tacho drive over temperature LOGGED
FAULT 08-04 gearbox/abs drive overtemperature LOGGED
FAULT 08-05 air conditioning clutch over temperature LOGGED
FAULT 08-06 mil lamp drive over temperature LOGGED
FAULT 08-07 glowplug relay drive overtemperature LOGGED
FAULT 10-01 air conditioning fan drive open load LOGGED
FAULT 10-02 fuel pump drive open load LOGGED
FAULT 10-03 tachometer open load LOGGED
FAULT 10-04 gearbox/abs drive open load LOGGED
FAULT 10-05 air conditioning clutch open load LOGGED
FAULT 10-06 mil lamp drive open load LOGGED
FAULT 10-07 glowplug lamp drive open load LOGGED
FAULT 10-08 glowplug relay drive open load LOGGED
FAULT 12-01 air conditioning fan drive open load CURRENT
FAULT 12-02 fuel pump drive open load CURRENT
FAULT 12-03 tachometer open load CURRENT
FAULT 12-04 gearbox/abs drive open load CURRENT
FAULT 12-05 air conditioning clutch open load CURRENT
FAULT 12-06 mil lamp drive open load CURRENT
FAULT 12-07 glowplug lamp drive open load CURRENT
FAULT 14-01 air conditioning fan drive open load CURRENT
FAULT 14-02 fuel pump drive open load CURRENT
FAULT 14-03 tachometer open load CURRENT
FAULT 14-04 gearbox/abs drive open load CURRENT
FAULT 14-05 air conditioning clutch open load CURRENT
FAULT 14-06 mil lamp drive open load CURRENT
FAULT 14-07 glowplug lamp drive open load CURRENT
I'm not too fond of all the over temp stuff(and of course that's what I', really interested in finding out what is), but I guess the "open load" means that they're ok?
-although they say "FAULT"
Any advice appreciated.
/tony
I'd delete the whole bluddy lot and see what comes back, thats usually what I do as with a list like that 90% of them are complete cock!
Open load probably means open circuit i.e. disconnected. Clear them all, go for a drive and see if any come back. If they don't, maybe check it after a week but otherwise don't worry about the ones that don't reappear! I have regularly seen Td5s which claim they have open circuits on all 5 injectors but they run better than they ought to in that condition....!
Jeez that's quite a list. When I did mine a few weeks back it only had three faults.
Like BogMonster says, they'll have been logged over a long time and most will be just momentary loose connections. Clear the lot, take her for a good run and see what comes back - then deal with those!
I agree also. The 'open load' ones will be due to some high resistance in one or more connectors. Measureing resistance is one way that the ECU can 'detect' open circuits.
I would also go for a clear down and see what comes back. Any current faults will show up pretty quickly.
