tweetyduck Posted April 14, 2010 Share Posted April 14, 2010 i think its FRC7970 for the nut and 606474 for the bearing. What do you think, those the correct parts? do you think its full stip to replace it? Quote Link to comment Share on other sites More sharing options...
western Posted April 14, 2010 Share Posted April 14, 2010 (edited) parts here acrobat reader page 73 of 98/ parts book page 369 FRC7970 for the nut and 606474 for the bearing numbers are good. Nut Bearing Edited April 14, 2010 by western Quote Link to comment Share on other sites More sharing options...
nickwilliams Posted April 14, 2010 Share Posted April 14, 2010 That's the wrong bearing, Mr Western! Les's guide is for changing the output shaft bearing, whereas the OP's question relates to the rear bearing on the differential shaft, which you can only get at by taking the transfer differential out from the other (front) side of the box. Nick. Quote Link to comment Share on other sites More sharing options...
western Posted April 14, 2010 Share Posted April 14, 2010 That's the wrong bearing, Mr Western! Les is guide is for changing the output shaft bearing, whereas the OP's question relates to the rear bearing on the differential shaft, which you can only get at by taking the transfer differential out from the other (front) side of the box. Nick. link removed & parts page link amended, I've never removed the centre diff, best I can suggest is read the workshop manual/RAVE or send a e.mail to Ashcrft Transmissions requesting advice or just replace the complete transfer box, seems like what looked to be a tidy & uptogether 110 is not quite what it looked. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted April 14, 2010 Author Share Posted April 14, 2010 thanks fof the confirmation. It could have happend anytime. The rest of the box is perfect. I've just stripped it and its all OK except that single bearing. I might replace the others, but to be honest they all look good. Looks like the cage broke up and spilled the rollers. No damage internally just that one. So i know have a completely dismantled trans box. I'll order the parts. TA. ps called Ashcrofts...get the feeling the are a bit busy as they were little help. Quote Link to comment Share on other sites More sharing options...
