reb78 Posted August 31, 2017 Share Posted August 31, 2017 I've always found the D2 to rev fairly high at motorway speeds. I've also found that mine has a decent amount of pull left at these speeds too. As such, i was wondering what folks thought about fitting a 1.4:1 transfer box plus GKN overdrive to the vehicle? What technical issues might i encounter in doing so? (no need for discussion about the reliability of the GKN ODs, I am aware of these and run one successfully on the 110). Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 31, 2017 Share Posted August 31, 2017 #1 question is is there room for it under a D2? #2 question is manual or auto? Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 31, 2017 Author Share Posted August 31, 2017 I believe you need to modify the body slightly at the back of the transmission tunnel. I have a vague recollection that GKN made an input gear for these for the 1.2 transfer boxes when they came out as the input gear has a different number of teeth (??) to the 1.4 ratio box, so you could fit them with a little modification. However, even if you coudl find an input gear I reckon the 1.2 plus the GKN would make the final gears too tall, hence the thought about going over to a 1.4 transfer box plus the GKN. Mine is a manual. Quote Link to comment Share on other sites More sharing options...
