J.A.G_100 Posted September 8, 2017 Share Posted September 8, 2017 Hi Guys, So I changed all my side lights (except reverse light) to LED and ever since the little green dash trailer light is always on, regardless of lights on or off, permanently on. Do I just need to change the Relay? I had to swap the relay and use the one the LED kit came with to make the indicators flash correctly as the indicator flashed super quick with the original Relay in. Any help would be great! Ive had this for about 2 years now but never bothered to sort as I never towed with the 110, however Ive just bought a trailer and want to get it sorted! Cheers in advance. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted September 8, 2017 Share Posted September 8, 2017 Mines got a little nob on top off the relay , you turn that till the trailer light goes out I believe. Didn't need to do mine when I fitted them as all worked ok . Bolt on bits sell the relay with the adjuster nob on the top. cheers Ian Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 8, 2017 Share Posted September 8, 2017 I did the LED light conversion on a 2002 Td5, used the Wipec LED relay with a tuneable resistor - i.e. the knob on the top. and FYI to get the thing tuned properly you need to do it with a trailer socket plugged in. I didn't and it threw the new owner when he plugged a trailer into it, he had to pop back behind the dash console and re adjust the resistor slightly. Quote Link to comment Share on other sites More sharing options...
J.A.G_100 Posted September 8, 2017 Author Share Posted September 8, 2017 8 hours ago, Maverik said: I did the LED light conversion on a 2002 Td5, used the Wipec LED relay with a tuneable resistor - i.e. the knob on the top. and FYI to get the thing tuned properly you need to do it with a trailer socket plugged in. I didn't and it threw the new owner when he plugged a trailer into it, he had to pop back behind the dash console and re adjust the resistor slightly. Ah that makes sense as the new relay has got an adjustable knob on top and I've just bought a trailer tonight so I'll go and try that out in the morning! thanks Quote Link to comment Share on other sites More sharing options...
