MuddyWinny Posted September 19, 2017 Share Posted September 19, 2017 Is it ok to clean the rear crank seal journal with brake cleaner? After fitting one and having it leak I'm cautious about damaging the Teflon seal. Thanks Mark Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 20, 2017 Share Posted September 20, 2017 Do you mean the face at which the rear seal runs on? if you've got the bell housing split from the engine and have room, I'd highly recommend you just replace the seal, if you get a genuine one they usually come with a handy installation aid, add a smear of engine oil to assist it slipping on, should be fine. just make sure the landing face of the flywheel flange is nice and even with no scores or anything, if its rough just polish with a super fine emery paper. Quote Link to comment Share on other sites More sharing options...
MuddyWinny Posted October 1, 2017 Author Share Posted October 1, 2017 Hello, Yes. Hmm, everything I have read says to fit the seal dry. Since the old one leaked I needed to clean oil from the journal. I've fitted a seal from Turner Engineering. I guess I'll find out how long it lasts... Thanks for replying. Mark Quote Link to comment Share on other sites More sharing options...
