nige90 Posted December 11, 2006 Share Posted December 11, 2006 Expected the clutch failure to be the fork but no, the stupid plastic release bearing has melted. Are they always plastic or can I get a decent one made of proper materials and if so where ? Nige Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 11, 2006 Share Posted December 11, 2006 The only ones I have seen are plastic bodied but may be other racing spec ones that will fit, or something like that? Never seen one melted though, suggests to me you have another problem that needs investigating! Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted December 11, 2006 Share Posted December 11, 2006 Are they always plastic or can I get a decent one made ofproper materials and if so where ? Nige Rakeway heavy duty aluminium thrust bearing Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted December 11, 2006 Share Posted December 11, 2006 Never seen one melted though, suggests to me you have another problem that needs investigating! I know of a few, a friends went the other week, its good practice to pack with grease (done right it doesnt get the plate). Quote Link to comment Share on other sites More sharing options...
Les Henson Posted December 11, 2006 Share Posted December 11, 2006 I've only seen ones that have melted because of other problems, such as the bearing itself siezing. Les. Quote Link to comment Share on other sites More sharing options...
john cranfield Posted December 11, 2006 Share Posted December 11, 2006 I've only seen ones that have melted because of other problems, such as the bearing itself siezing.Les. Les is right on. There's no problem using the plastic one all the while the bearing is good. If the bearing seizes or gets hot the plastic melts but that is a result of a failure not the cause. John Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted December 11, 2006 Share Posted December 11, 2006 Les is right on. There's no problem using the plastic one all the while the bearing is good. If the bearing seizes or gets hot the plastic melts but that is a result of a failure not the cause.John Couldnt agree more, the one I saw was a direct result of not having the bellhousing sealed properly, a lot of wading in an ex cement quarry and seizure! Quote Link to comment Share on other sites More sharing options...
