James NZ Posted December 20, 2017 Share Posted December 20, 2017 Hi everyone, went to start the wife's TD5 this morning (our main car) and got a single click but no start. It clicked when I realised the ignition key and the click appears to be from the starter. I've done a search and am about to clean all terminals etc, will put the battery on charge, will also see if the car starts by using the V8 battery (830cca). The TD5 starter had new contacts and plunger 22193km ago. I read somewhere that a single click is the relay and or solenoid, but rapid or multiple clicks indicates a dying battery, this sounds correct? With New Zealand about to close tomorrow at lunchtime (Friday) for the xmas holidays any other pointers will be helpful and may just reduce my stress levels! Thanks, James NZ Quote Link to comment Share on other sites More sharing options...
Shackleton Posted December 20, 2017 Share Posted December 20, 2017 Check that the spade connectors to the starter terminals are all on fully - they can work loose yet look fine so push them on hard regardless. I had similar symptoms caused by that problem. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 21, 2017 Share Posted December 21, 2017 I'd guess the terminals inside the solenoid. Flick the key loads of times and if it eventually cranks on one of the turns, it's almost certainly that. Quote Link to comment Share on other sites More sharing options...
James NZ Posted December 21, 2017 Author Share Posted December 21, 2017 Hi guys, thanks for the replies, it turned out to be the contacts within the starter solenoid. Just picked some up locally and will fit them but I think the underlying problem is that the solenoid had quite a lot of oil in it which had affected the terminals. So I'll also need to figure out where the engine is leaking from and sort that out as well. My wife mentioned the other day that the car was "clonking", think I found the problem as per the pic. Fortunately I already have a rebuild kit in stock for the driveshaft. Have a merry christmas. Cheers, James NZ Quote Link to comment Share on other sites More sharing options...
