ianmayco68 Posted December 28, 2017 Share Posted December 28, 2017 Hi all , fitting my electric lift pump today and encountered a problem. One of the nuts welded on the inside of the bulkhead that holds the fuel filter on have come off , so tried a rivnut but the shoulders were to small so before I open the hole out to put in a larger rivnut which I’ll need to get anyway dose anyone know if there is a better fixing that I can use other than a rivnut ? cheers Ian Quote Link to comment Share on other sites More sharing options...
cackshifter Posted December 28, 2017 Share Posted December 28, 2017 A rawlnut may be easier - they are quite strong but don't overtighten. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted December 28, 2017 Author Share Posted December 28, 2017 Cheers that looks like a much better solution as the hole is bigger than the bolt size , and the hole got split in places when I was getting the rivnut out that I tried. cheers Ian Quote Link to comment Share on other sites More sharing options...
