headdamage Posted December 13, 2006 Share Posted December 13, 2006 Hi, Does anyone know if there is a bellhousing or adaptor that fits the the 200 or 300 TDI onto a Rover V8 (long input shaft) LT77S transmission? Thanks Quote Link to comment Share on other sites More sharing options...
muddy Posted December 13, 2006 Share Posted December 13, 2006 Hi,Does anyone know if there is a bellhousing or adaptor that fits the the 200 or 300 TDI onto a Rover V8 (long input shaft) LT77S transmission? Thanks I took my disco 200 Tdi out of a rrc with a lt77 long shaft box and mated it to my lt77 defender short shaft box all i had to do was remove the locating dowels and re tap the engine backplate for 4 new studs then it just slipped on so i think disregarding the studs they are interchangeable. Quote Link to comment Share on other sites More sharing options...
Andy Posted December 13, 2006 Share Posted December 13, 2006 i think your talking about the wrong shaft there muddy. its the input shaft that varies according to V8/Tdi. ive got a feeling that the bearing in the flywheel is a different size depending on fuel. probably easier to strip the boxes & swop the input shafts & bellhousings. Quote Link to comment Share on other sites More sharing options...
RoLandRover Posted December 13, 2006 Share Posted December 13, 2006 i think your talking about the wrong shaft there muddy. its the input shaft that varies according to V8/Tdi. ive got a feeling that the bearing in the flywheel is a different size depending on fuel. probably easier to strip the boxes & swop the input shafts & bellhousings. To bad you weren't around some months ago! I had the same problem the other way around I haven't got my Disco tdibox no more,.... I still haven't found a proper one to be honest When test driving for the first time last week , the reverse didn't work .. .. .. for some reason there are plenty more differences as well internal, as external within the LT77 range over the years, and models....... Anyways,.. need to say this forum is superb for all the knowledge around! i'll never abandon our Dutch green-prikkers-forum but for the specials Ãll always keep an eye on this place! grtzz, RoLandRover Quote Link to comment Share on other sites More sharing options...
Henry Webster Posted December 14, 2006 Share Posted December 14, 2006 I should flog the V8 box, because they are rarer and worth something and buy a Tdi box because the are ten-a-penny. H Quote Link to comment Share on other sites More sharing options...
Andy Posted December 14, 2006 Share Posted December 14, 2006 if it would help i have a workshop manual for the LT77S box on my pc. once i get that back online i could send it to you, i might have one that covers the early boxes too cant remember. my LT77 isnt a S but the pics werent that far out when i took it apart. Quote Link to comment Share on other sites More sharing options...
muddy Posted December 14, 2006 Share Posted December 14, 2006 i think your talking about the wrong shaft there muddy. its the input shaft that varies according to V8/Tdi. ive got a feeling that the bearing in the flywheel is a different size depending on fuel. probably easier to strip the boxes & swop the input shafts & bellhousings. I did mean the input shaft/ first motion shaft but tyes it does look like i'm referring to short stick/long stick boxs Thanks for hilighting this. Quote Link to comment Share on other sites More sharing options...
Martin90 Posted December 19, 2006 Share Posted December 19, 2006 Hi,Does anyone know if there is a bellhousing or adaptor that fits the the 200 or 300 TDI onto a Rover V8 (long input shaft) LT77S transmission? Thanks If you decide to change for the correct Tdi box, I am in need of a V8 LT-77 box provided it is a long stick as per 90/110. Please drop me a line if you are selling. Cheers, MArtin Quote Link to comment Share on other sites More sharing options...
