Tractorman Posted January 25, 2018 Share Posted January 25, 2018 My 300tdi has developed a knock on the front axle, o/s I think. It is fairly constant, 1 knock for a wheel revolution, worse straight ahead under load and much less without power. Doesn't change with cornering. I'm assuming its the cv joint but could it be anything else? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 25, 2018 Share Posted January 25, 2018 Stuff stuck in the wheel? Collapsed wheel bearing? Quote Link to comment Share on other sites More sharing options...
Tractorman Posted January 26, 2018 Author Share Posted January 26, 2018 It does sound exactly like something stuck in the wheel, but it stops if you lift off the power. No obvious play in the wheel bearings. Will try the CV and see if it stops. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 26, 2018 Share Posted January 26, 2018 If that's the case, check your prop UJs first, much easier to check than a CV... Quote Link to comment Share on other sites More sharing options...
