russ1 Posted December 13, 2006 Share Posted December 13, 2006 Is this any good to build a cage? 3 60 degree bends ??? Thanks Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted December 14, 2006 Share Posted December 14, 2006 Hi there, sorry your post doesn't seem to make sense - was there a link you forgot to add? Does that say '3 x 60 degree bends' or '360 degree bends'? And either way, what does it mean? Perhaps if you clarify we can help further? Al. Quote Link to comment Share on other sites More sharing options...
russ1 Posted December 28, 2006 Author Share Posted December 28, 2006 might have known i would forget somthing like that. Its ebay number 150041572466 Quote Link to comment Share on other sites More sharing options...
nige90 Posted December 28, 2006 Share Posted December 28, 2006 This one Bender Yep, that'll do nicely sir. You'll have great fun working out how to get your bends in the right places at first Quote Link to comment Share on other sites More sharing options...
Warthog Posted December 29, 2006 Share Posted December 29, 2006 Researched Tube benders for awhile and this type seem the most favourable: USA WWW: http://www.vansantent.com/model_3_bender.htm UK WWW: http://www.straightforwardsupplies.co.uk/a...conversion.html I know they are twice the cost of the model you are looking at though! But they end up in most serious builders images on the US Fabrication forums. The pound is pretty good at the moment. So an email to the US www could be the oppo to get a good deal? Plus the Angle plate will make easy work of achieving good symetrical shape to ya cage etc. Mark Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 30, 2007 Share Posted April 30, 2007 I have just bought a Sealey 10-ton pipe bender. Most of the comments on this make was good. Yet to use it though - still waiting for my new chassis. Les. Quote Link to comment Share on other sites More sharing options...
biasbilt Posted April 30, 2007 Share Posted April 30, 2007 Researched Tube benders for awhile and this type seem the most favourable:USA WWW: http://www.vansantent.com/model_3_bender.htm UK WWW: http://www.straightforwardsupplies.co.uk/a...conversion.html I know they are twice the cost of the model you are looking at though! But they end up in most serious builders images on the US Fabrication forums. The pound is pretty good at the moment. So an email to the US www could be the oppo to get a good deal? Plus the Angle plate will make easy work of achieving good symetrical shape to ya cage etc. Mark I have one of these and a Staffa crush type bender and there are advantages to both. The US style will give a better bend with less deformation, the angle plate is useful, and repetitive. It's slow to use, and can be tricky to get all the bends starting from the right direction, as it pulls past the wiper die. It is easy when all the bends are in the same plane like a rear hoop, but for the front hoop, wheere it lays back against the screen, one bend needs to be done from below and one from above that bend. Not impossible, but you need to be accurate to get them both in the same palne. You also need a garage big enough to bolt it to the floor so you can pull against the lever, or convert to hydraulic, and to allow the end to swing about. The choice of dies is limited for UK tube, as they don't do many metric formers, but you can get one for 1 1/2" NB pipe, which is Blue Band. It will also do 180 degree bends which is useful for shock hoops etc. The crush bender will not give quite such nice bends (you tend to get 3 little ridges form in the inside of the bend, which are barely noticeable unless you know to look for them), is a little quicker and is more portable. There is a greater choice of formers available. Which one? Well I use both for different jobs, tending to use the US style for the important bends and the UK type for tweaks and less important bends/funny sizes. Hope that helps. Toby Quote Link to comment Share on other sites More sharing options...
101nut Posted April 30, 2007 Share Posted April 30, 2007 I have just bought a Sealey 10-ton pipe bender. Most of the comments on this make was good. Yet to use it though - still waiting for my new chassis. Les. If this is the same as the machine mart one, my mate bought one and the hydraulics work well. However the formers were cheap and the walls flex too much on 2" blue band so the pipe deforms ... he took it back and hired a good one for the day instead! Cheaper, quicker, better results - three cages in the day plus the odd roll hoop! AndyG Quote Link to comment Share on other sites More sharing options...
