garrygun Posted December 17, 2006 Share Posted December 17, 2006 Hi guys, ser 2b diesel could sombody tell me what voltage i should get from the resistor that supplies heater plugs from 1 to 4 should this decrease from plug to plug?? thanks in advance for your knowlege guys. Cheers Garry. Quote Link to comment Share on other sites More sharing options...
john cranfield Posted December 18, 2006 Share Posted December 18, 2006 Hi guys, ser 2b diesel could sombody tell me what voltage i should get from the resistor that supplies heater plugs from 1 to 4 should this decrease from plug to plug?? thanks in advance for your knowlege guys.Cheers Garry. The plugs were wired in series so that the voltage measured at each one will decrease. It is common to change to a later type that are not series connected. John Quote Link to comment Share on other sites More sharing options...
garrygun Posted December 19, 2006 Author Share Posted December 19, 2006 The plugs were wired in series so that the voltage measured at each one will decrease.It is common to change to a later type that are not series connected. John Thanks John, i think i will try later plugs dont realy rate these early type. cheers Garry. Quote Link to comment Share on other sites More sharing options...
garrygun Posted December 21, 2006 Author Share Posted December 21, 2006 The plugs were wired in series so that the voltage measured at each one will decrease.It is common to change to a later type that are not series connected. John Hi John, ive tried to locate some modded heater plugs,tried few suppliers just drawn a blanc. would you know of a supplier that could help? regards Garry.l Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted December 22, 2006 Share Posted December 22, 2006 Hi John, ive tried to locate some modded heater plugs,tried few suppliers just drawn a blanc.would you know of a supplier that could help? regards Garry.l Try Paddock spares for their part number GAM100, its a set of 4 parallel wired plugs with the new wiring to suit. £17 something if i remember correctly. Dont get parallel wired plugs for a 2.5D they are not what you want as the threads are different. Quote Link to comment Share on other sites More sharing options...
garrygun Posted December 23, 2006 Author Share Posted December 23, 2006 Try Paddock spares for their part number GAM100, its a set of 4 parallel wired plugs with the new wiring to suit. £17 something if i remember correctly.Dont get parallel wired plugs for a 2.5D they are not what you want as the threads are different. Thanks Phil, i will get in touch with them asap. cheers Garry. Quote Link to comment Share on other sites More sharing options...
Jorge Rondao Posted December 30, 2006 Share Posted December 30, 2006 Hi, the plugs that searches you can to find here ALLMAKES 4X4 I leave some photos of the new plugs in parallel that I together with took off the project of assembly of the same ones to help you to mount. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted December 30, 2006 Share Posted December 30, 2006 If you buy the 12v glow plug modification kit, you have to bypass the resistor. Not the indicator bulb wire though. Les. Quote Link to comment Share on other sites More sharing options...
